Hi
I have setup password protection for em client. And I try to windows task scheduler to open em client. so what is the script parameter for password protection.
Thanks
George
Hi
Thanks
George
If you open eM Client with Task Scheduler, you will still be prompted for the password. That is what this function does. If you could bypass or automate entering the password, what would be the point?
Also, please note that the password only interrupts the application start. The database is not protected in any way and can still be opened on another installation of eM Client.
Thanks Gary, You are right. But don’t worry about the security issues. Just wondering if it is possible?
