have tried uninstalling and reinstalling. have tried the same with deleting folder in appdata/roaming
have tried to run with elevated prompt.
running in a 64-bit windows 7 virtual machine
Hi Bob,
Which version of eM Client are you trying to install?
Has eM Client worked correctly for you before? Or is this the first time you’re trying eM Client?
In which ‘virtual machine’ are you trying eM Client? VM Workstation? Which version?
Hi Hans,
Thanks for your reply.
I am not sure what the existing version was, but I tried downloading and installing the latest version I could download from the website. I first tried installing over top, then uninstalling from windows and reinstalling, then uninstalling and removing all registry entries and folders (except what I found in the winsxs folder). Then I found a link to a newer version in a post by a guy with a similar system.drawing thing, but different problem, so I did the same things with that version. The error reports indicate the current version is eM Client (6.0.21151.0)
Yes, EM Client has worked correctly in the past. To be clear, I do not use windows so my primary email client is not em client, but I have some clients who use it so I keep it on a vm for testing. it has been several months since I last tried to use it, and I kind of think I couldn’t get it working then either, but I did have it working on this VM at one point, for sure.
the VM is virtualbox 4.2.26.
For grins and giggles, I fired up an old old VM of win7, downloaded EM Client, and it installed and worked just fine there. Unfortunately that provided zero enlightenment as to ow to fix it on this VM.
I have ensured all windows updates are in place, I have tried windows safe mode, I have tried running in elevated mode, I have tried all sorts of different compatibility modes, I have tried multiple screen resolutions. all produce the same error.
I get the feeling looking through the error that the problem is probably related to the .net framework, so I tried a repair on that and checked for updates, but that also did not fix the problem. it is currently 4.5.1.
Hi Bob, does the application keep showing this error while you’re using the application or is it displayed after an application crash?
Can you please make a screenshot of the error or copy the content of the error after the crash report window is shown?
Hi Paul,
Thank you for jumping in…
The application will not open, all I get is an error report after checking the database:
eM Client (6.0.21151.0)Windows: Microsoft Windows NT 6.1.7601 Service Pack 1, Framework: 4.0.30319.18444
System.ArgumentException: Parameter is not valid.
at System.Drawing.Font.GetHeight(Graphics graphics)
at System.Drawing.Font.get_SizeInPoints()
at System.Drawing.SystemFonts.FontInPoints(Font font)
at System.Drawing.SystemFonts.get_MessageBoxFont()
at MailClient.UI.Forms.ThemeForm…ctor(Boolean ignoreTheme)
at MailClient.UI.Forms.BorderlessForm…ctor()
at MailClient.UI.Forms.formMain…ctor(List1 arguments) at MailClient.Program.CreateMainForm(Boolean startupInit, List
1 args)
at MailClient.Program.Main(String[] args)
" rel=“nofollow” target="_blank">http://emclient.com/ns/report">;
eM Client
6.0.21151.0
false
4.0.30319.18444
System.Drawing.dll
100664949
System.Drawing
System.Drawing.Font
GetHeight
System.Drawing
System.Drawing.Graphics
graphics
0
1190b1
System.Drawing.dll
100664954
System.Drawing
System.Drawing.Font
get_SizeInPoints
22
be
System.Drawing.dll
100664660
System.Drawing
FontInPoints
System.Drawing
System.Drawing.Font
font
0
25
System.Drawing.dll
100664653
System.Drawing
get_MessageBoxFont
64
e4
MailClient.exe
100667220
MailClient
.ctor
mscorlib
System.Boolean
ignoreTheme
2e
70
MailClient.exe
100674587
MailClient
.ctor
5a
d5
MailClient.exe
100693073
MailClient
.ctor
mscorlib
System.Collections.Generic.List1[[System.String, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]]</type><br> <name>arguments</name><br> </parameter><br> </parameters><br> </method><br> <offset>46</offset><br> <nativeoffset>b9</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100675785</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Program</type><br> <name>CreateMainForm</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>startupInit</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Collections.Generic.List
args
8
2e
MailClient.exe
100675783
MailClient
MailClient.Program
Main
mscorlib
System.String[]
args
1229
2a6a
MailClient.exe
C:\Program Files (x86)\eM Client\MailClient.exe
MailClient.exe
MailClient.exe
6.0.21151.0
eM Client
eM Client
6.0.21151.0
False
False
False
False
False
Language Neutral
ntdll.dll
C:\Windows\SysWOW64\ntdll.dll
ntdll.dll
ntdll.dll.mui
6.1.7600.16385 (win7_rtm.090713-1255)
NT Layer DLL
Microsoft® Windows® Operating System
6.1.7600.16385
False
False
False
False
False
English (United States)
MSCOREE.DLL
C:\Windows\SYSTEM32\MSCOREE.DLL
mscoree.dll
mscoree.dll
4.0.40305.0 (Main.040305-0000)
Microsoft .NET Runtime Execution Engine
Microsoft® .NET Framework
4.0.40305.0
False
False
False
True
False
KERNEL32.dll
C:\Windows\syswow64\KERNEL32.dll
kernel32
kernel32
6.1.7601.18015 (win7sp1_gdr.121129-1432)
Windows NT BASE API Client DLL
6.1.7601.18015
False
False
False
False
False
KERNELBASE.dll
C:\Windows\syswow64\KERNELBASE.dll
Kernelbase
Kernelbase
6.1.7601.18015
False
False
False
False
False
ADVAPI32.dll
C:\Windows\syswow64\ADVAPI32.dll
advapi32.dll
advapi32.dll.mui
Advanced Windows 32 Base API
6.1.7600.16385
False
False
False
False
False
msvcrt.dll
C:\Windows\syswow64\msvcrt.dll
msvcrt.dll
msvcrt.dll
7.0.7601.17744 (win7sp1_gdr.111215-1535)
Windows NT CRT DLL
7.0.7601.17744
False
False
False
False
False
sechost.dll
C:\Windows\SysWOW64\sechost.dll
sechost.dll
sechost.dll.mui
Host for SCM/SDDL/LSA Lookup APIs
6.1.7600.16385
False
False
False
False
False
RPCRT4.dll
C:\Windows\syswow64\RPCRT4.dll
rpcrt4.dll
rpcrt4.dll.mui
Remote Procedure Call Runtime
6.1.7600.16385
False
False
False
False
False
SspiCli.dll
C:\Windows\syswow64\SspiCli.dll
security.dll
security.dll
6.1.7601.18526 (win7sp1_gdr.140706-1506)
Security Support Provider Interface
6.1.7601.18526
False
False
False
False
False
CRYPTBASE.dll
C:\Windows\syswow64\CRYPTBASE.dll
cryptbase.dll
cryptbase.dll
Base cryptographic API DLL
6.1.7600.16385
False
False
False
False
False
mscoreei.dll
C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll
mscoreei.dll
mscoreei.dll
4.0.30319.18408 built by: FX451RTMGREL
4.0.30319.18408
False
False
False
True
False
SHLWAPI.dll
C:\Windows\syswow64\SHLWAPI.dll
SHLWAPI
SHLWAPI.DLL.MUI
Shell Light-weight Utility Library
6.1.7600.16385
False
False
False
False
False
GDI32.dll
C:\Windows\syswow64\GDI32.dll
gdi32
gdi32
6.1.7601.18577 (win7sp1_gdr.140822-1508)
GDI Client DLL
6.1.7601.18577
False
False
False
False
False
USER32.dll
C:\Windows\syswow64\USER32.dll
user32
user32
6.1.7601.17514 (win7sp1_rtm.101119-1850)
Multi-User Windows USER API Client DLL
6.1.7601.17514
False
False
False
False
False
LPK.dll
C:\Windows\syswow64\LPK.dll
LanguagePack
LanguagePack
6.1.7601.18177 (win7sp1_gdr.130605-1534)
Language Pack
6.1.7601.18177
False
False
False
False
False
USP10.dll
C:\Windows\syswow64\USP10.dll
Uniscribe
Uniscribe
1.0626.7601.18454 (win7sp1_gdr.140424-1533)
Uniscribe Unicode script processor
Microsoft® Uniscribe Unicode script processor
1.0626.7601.18454
False
False
False
False
False
IMM32.DLL
C:\Windows\system32\IMM32.DLL
imm32
imm32
Multi-User Windows IMM32 API Client DLL
6.1.7601.17514
False
False
False
False
False
MSCTF.dll
C:\Windows\syswow64\MSCTF.dll
MSCTF
MSCTF.DLL.MUI
MSCTF Server DLL
6.1.7600.16385
False
False
False
False
False
clr.dll
C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll
clr.dll
clr.dll
4.0.30319.18444 built by: FX451RTMGDR
Microsoft .NET Runtime Common Language Runtime - WorkStation
4.0.30319.18444
False
False
False
True
False
MSVCR110_CLR0400.dll
C:\Windows\system32\MSVCR110_CLR0400.dll
msvcr110_clr0400.dll
11.00.50938.18408 built by: FX451RTMGREL
Microsoft® C Runtime Library
Microsoft® Visual Studio® 11 Beta
11.00.50938.18408
False
False
False
False
False
mscorlib.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\mscorlib\ce5f61c5754789df97be8dc991c47d07\mscorlib.ni.dll
mscorlib.dll
mscorlib.dll
Microsoft Common Language Runtime Class Library
4.0.30319.18444
False
False
False
True
False
ole32.dll
C:\Windows\syswow64\ole32.dll
OLE32.DLL
OLE32.DLL.MUI
Microsoft OLE for Windows
6.1.7600.16385
False
False
False
False
False
uxtheme.dll
C:\Windows\system32\uxtheme.dll
UxTheme.dll
UxTheme.dll.mui
Microsoft UxTheme Library
6.1.7600.16385
False
False
False
False
False
System.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\System\17a393b77ae757f0768501fb95ff5af6\System.ni.dll
System.dll
System.dll
4.0.30319.34238 built by: FX452RTMGDR
.NET Framework
4.0.30319.34238
False
False
False
True
False
CRYPTSP.dll
C:\Windows\system32\CRYPTSP.dll
cryptsp.dll
cryptsp.dll
Cryptographic Service Provider API
6.1.7601.18526
False
False
False
False
False
rsaenh.dll
C:\Windows\system32\rsaenh.dll
rsaenh.dll
rsaenh.dll
Microsoft Enhanced Cryptographic Provider
6.1.7600.16385
False
False
False
False
False
MailClient.Collections.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient.1d52ed9e#\00bda4eadf35b24c165128cef4bc420e\MailClient.Collections.ni.dll
MailClient.Collections.dll
6.0.21151.0
6.0.21151.0
False
False
False
False
False
Language Neutral
MailClient.Mail.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient.Mail\9a02e787063da387a556051474595f97\MailClient.Mail.ni.dll
MailClient.Mail.dll
MailClient.Mail.dll
6.0.21151.0
6.0.21151.0
False
False
False
False
False
Language Neutral
HTMLEditorControl.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\HTMLEditorControl\22f1c0751fa4f249ae86ed62cd9286a2\HTMLEditorControl.ni.dll
HTMLEditorControl.dll
6.0.21151.0
HtmlEditorControl
6.0.21151.0
False
False
False
False
False
Language Neutral
MailClient.ni.exe
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient\6c6396ec0e5b3f97a060237d2208bf04\MailClient.ni.exe
MailClient.exe
MailClient.exe
6.0.21151.0
eM Client
eM Client
6.0.21151.0
False
False
False
False
False
Language Neutral
System.Drawing.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Drawing\b4c08872c259018b17b2801da33ac80f\System.Drawing.ni.dll
System.Drawing.dll
System.Drawing.dll
.NET Framework
4.0.30319.18408
False
False
False
True
False
System.Windows.Forms.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Windows.Forms\db563d596d76daed04e9b5d25b2f4cb9\System.Windows.Forms.ni.dll
System.Windows.Forms.dll
.NET Framework
4.0.30319.18408
False
False
False
True
False
MailClient.Common.UI.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient.Common.UI\55901a97ee1fc56ba93f256cf2c84e79\MailClient.Common.UI.ni.dll
MailClient.Common.UI.dll
6.0.21151.0
6.0.21151.0
False
False
False
False
False
Language Neutral
MailClient.Interop.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient.Interop\6191794086706ce1c9a82f28930cb577\MailClient.Interop.ni.dll
MailClient.Interop.dll
6.0.21151.0
6.0.21151.0
False
False
False
False
False
Language Neutral
MailClient.ExceptionUtils.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient.ad6c0f7b#\b0abb8ae780fb256f2fe0308d01062d8\MailClient.ExceptionUtils.ni.dll
MailClient.ExceptionUtils.dll
1.0.0.0
1.0.0.0
False
False
False
False
False
Language Neutral
gdiplus.dll
C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.18455_none_72d576ad8665e853\gdiplus.dll
gdiplus
gdiplus
6.1.7601.18455 (win7sp1_gdr.140425-1537)
Microsoft GDI+
6.1.7601.18455
False
False
False
False
False
LinqBridge.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\LinqBridge\b91126b3cc09ba878acfbbcf3d32be2c\LinqBridge.ni.dll
LinqBridge.dll
LinqBridge.dll
1.3.13216.2214
LINQBridge
LINQBridge
1.3.13216.2214
False
False
False
False
False
Language Neutral
System.Configuration.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Configuration\0648dbecb7e3fb9523565107e04a5caf\System.Configuration.ni.dll
System.Configuration.dll
4.0.30319.18408
False
False
False
True
False
System.Xml.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Xml\7147fa233a070283dba824da40089bf1\System.Xml.ni.dll
System.Xml.dll
System.Xml.dll
4.0.30319.34234 built by: FX452RTMGDR
.NET Framework
4.0.30319.34234
False
False
False
True
False
nlssorting.dll
C:\Windows\Microsoft.NET\Framework\v4.0.30319\nlssorting.dll
nlssorting.dll
nlssorting.dll
Microsoft Collation Support
4.0.30319.18408
False
False
False
True
False
secur32.dll
C:\Windows\system32\secur32.dll
secur32.dll
secur32.dll
6.1.7601.18526
False
False
False
False
False
credssp.dll
C:\Windows\system32\credssp.dll
credssp.dll
credssp.dll
6.1.7601.18540 (win7sp1_gdr.140716-1508)
Credential Delegation Security Package
6.1.7601.18540
False
False
False
False
False
comctl32.dll
C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.7601.18201_none_ec80f00e8593ece5\comctl32.dll
COMCTL32
Hi Bob, I’m sorry for my belated reply, however it seems like this issue is not actually related to eM Client rather than a system issue that might be related to use of some custom themes/fonts on your computer?
Are you aware of using such utility on your computer?
Hi Paul,
belated or not, thank you for taking the time to reply. I do appreciate it.
As stated before, I do not “use” this VM, it’s only real function is for testing and configuring software, such as em client, so I can do phone support and generally learn what I need to know before I show up to fix something for a client. As such, I have not installed any software on this machine that hasn’t also been installed somewhere else. Regardless, I take your point that something could have gotten installed somehow. The only thing in the programs list that I would identify as malware is outlook 2013, but to be sure I ran a scan with malwarebytes; it found a few things but removing them did not solve the problem.
I checked the themes in the control panel; the VM is running the default windows 7 basic theme and I see only three themes installed, and they all look like native default ones. I also checked the fonts; I am not sure how to identify any misbehaving fonts, but I found a button called restore default font settings and clicked it, but that also made no difference to the startup procedure or error message.
I would also mention that I am able to reproduce the problem when the VM is booted into safemode with networking. Same failure to start and same error. Perhaps my reasoning is flawed or lacks some bit of information, but I believe this to mean that the problem is not likely to be another program, and if it is due to a setting I have configured in windows, it is most likely something very fundamental in order for the setting to get loaded in safe mode.
One thing I can say that is different about this machine is that is is joined to a domain (also a testing thing). Given the nature of the error message and the fact that no other program fails to start, I don’t see how this could be the problem, but I would be remiss in not mentioning it…
Hi Bob, I have discussed the issue with the developers however what the crash report states is that system features are causing this crash on your device, which means we’re unable to resolve the issue from our side.
I’m sorry I couldn’t be more helpful in resolving the issue, however I personally still believe this might be related to the VM instance, did you come across this issue on any other computer where the application wasn’t installed on a virtual machine?
Can you try to setup a new database for eM client, if the issue persists or if it’s related to your current database? To setup a new database, please navigate to your local folder > app data > roaming and rename or remove the eM Client directory, next time you open the application a new database should be automatically setup.
Hi Paul,
Thanks for staying with me on this.
Is this the very top part that actually states the parameter is not valid, or is there some other clue in that pile of text that leads to the conclusion the problem is in the system and not the program? Maybe if I am pointed at what the problem actually is I can spend some time trying to figure it out…
I have not seen this particular error on other machines, no, but in another VM instance (a much older one I no longer use), using the same version of Virtualbox, a fresh install does not have this problem.
I have also tried deleting the folder in appdata, I found that as a possible fix before I posted the first time. I tried before and after installing, and again after removing all traces of em client from the registry after an uninstall and all folders that were not deleted by the uninstall.
Did you ever manage to solve the issue?
Hi Michael,
Not that I recall, no. The only customer I had using emclient has since moved to thunderbird…
sorry I can’t help more.
