SSL problems attempt to connect to server
I saw a lot of problems similar and try to found a solution without success…
I’m always getting this error:
https://i.imgur.com/BnVwHp8.png
With almost all accounts that I configure… does not matter the settings, ports that I set, etc… always get this error!
In this other site at end of the page https://www.calzadamedia.com/knowledgebase/kb228/em-client-imap-connection-errors/ “Cause & Solution” they said that this is a software problem and you guys already know about this issues…
Maybe the problem with my accounts are the same… because I already contact my mail provider and they try everything with me… different ports, different options! and this alert always is showing up!
There’s no solution to connect to imap without alerts?
Thanks!
Did you try disabling your anti-virus application and see if there is any difference?
