Could you please give the ability to stop the EM start window for activating. It just slows everything down
Could you please give the ability to stop the EM start window for activating. It just slows everything down.
If you are referring to the “splash screen” with tips loading on startup, “that wouldn’t be slowing eM Client opening”.
The splash screen just displays while the program is loading in the background as it’s got to load the database etc before the gui appears. So if you had no splash screen then it would probably be just a eg: blank screen for a bit.
However if you want to disable the Splash screen via a eg: Settings option, then there is a Sleekplan suggestion via the below link you can vote for.
hello
I don’t understand what you mean. Could you please clarify
