Spellcheck issue
Ever since the problem with the blue underlining of text, I’ve not been able to use the spellcheck facility. It underlines almost every word, eve3n if they are obviously spelt correctly and often gives alternative suggestions completely out of context to what I’m writing. For example, “lorry” as an alternative to “sorry.” Is there an answer?
lunes 07 marzo 2022 :: 1302hrs (UTC +01:00)
Hi @Suffolkman
I have never experienced this issue.
What version of eMC are you using?
What eMC Theme are you using?
Skybat
Будь ласка, підтримайте Україну будь-яким способом. Слава Україні
Смерть Путіну
emc_forum@compucall.com
Hablo español, luego portugués e inglés, con conocimiento de varios otros idiomas
