I’m about to start importing several gigabytes of email from a POP3 client I’ve been using for the past 20 years (!) (Becky! 2). I have a relatively wide and deep folder structure with about 330 folders. I’ve tried exporting/importing via MBOX files, but it’s not handling the folder structure (I think the issue may be on Becky!'s end, as I’ve also tried multiple tools available to convert MBOX files to PST files). So I’m resigned to exporting a folder at a time of emails from Becky! to a bunch of EML files into a file system folder. I’ve already generated the file system folder structure manually, which is actually a fairly efficient process.
But now I need to generate 330 folders/subfolders in my IMAP mail storage (Microsoft Outlook account via GoDaddy). I was hoping there would be a hotkey combo for “New Folder”, but I’m not seeing one. And of course it would be important that after typing in the name of the new folder and hitting enter, the focus should return to the parent folder, or at least, hitting the hotkey again should create the new folder at the same level as the previously created folder. Preferably then hitting Enter a second time would “enter” the folder having focus, allowing me to then create subfolders there if needed.
Can this be done in any way with the current version of eM Client?
Peter
