I have two gmail accounts and both work perfectly fine on any network through Chrome. I have recently moved to a new home and on that network eM Client’s SMTP gives problems and will not send emails, however via chrome or on other networks everything still works fine. I have tried changing the SMTP setting to legacy SSL/TLS but no luck…
Please see my log below:
10:08:03 AM ***@gmail.com [SMTP] MailClient.Accounts.ConnectionException: Connection failed due to the following reason:
10:08:03 AM “The handshake failed due to an unexpected packet format.” —> System.IO.IOException: The handshake failed due to an unexpected packet format.
10:08:03 AM at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)
10:08:03 AM at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)
10:08:03 AM at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)
10:08:03 AM at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)
10:08:03 AM at System.Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest)
10:08:03 AM at System.Net.Security.SslState.ProcessAuthentication(LazyAsyncResult lazyResult)
10:08:03 AM at System.Net.Security.SslStream.AuthenticateAsClient(String targetHost, X509CertificateCollection clientCertificates, SslProtocols enabledSslProtocols, Boolean checkCertificateRevocation)
10:08:03 AM at MailClient.Protocols.Smtp.SmtpSendCommand.Connect(WorkerStatus status)
10:08:03 AM — End of inner exception stack trace —
10:08:03 AM at MailClient.Protocols.Smtp.SmtpSendCommand.Execute(WorkerStatus status)
10:08:03 AM at MailClient.Commands.Command.Process(WorkerStatus status)
10:08:23 AM ***@gmail.com [IMAP] Synchronizing messages: For folder ***@gmail.com/[Gmail]/All Mail
10:08:23 AM ***@gmail.com [IMAP] Synchronizing messages: Done
10:08:23 AM ***@gmail.com [IMAP] Downloading messages: For folder ***@gmail.com/[Gmail]/All Mail
10:08:24 AM ***@gmail.com [IMAP] Downloading messages: Done
