I installed the program. pop3 and smtp server settings to be made. Here we use the smtp server port number 587 instead of 25. server requires a login. At the same internet connection, and MS Outlook and Mozilla Thunderbird installed on the same computer. Outlook and Thunderbird e-mail to get delivered without a problem. Pop3, smtp server works fine, but can not be accessed, however, on emclient. The error message says the user name or password is incorrect. On top of that I change the password on the server again. I’m testing it again no problem with Outlook and Thunderbird. But it still does not work emclient. Here is a sample account and have set up. What is the solution suggestion?
CONTACT: gzihar@gmail.com
email account: deneme@firatoto.com.tr
pop3 server: port 110 mail.firatoto.com.tr
SMTP server port 587 mail.firatoto.com.tr
User Name: deneme@firatoto.com.tr
password: “PLEASE ASK BY EMAIL.”
