Smart Folder label
hi
If you select several labels in the search folder, then all of them must be fulfilled or only one of the specified ones
if you use the smartfolder you can save yourself the rules
It is an OR argument, so messages that include any of the tags you specified in the Search Folder.
So in this example, any message that is tagged with Home, or any message that is tagged with Work.
and if i use an email as well, the email and a label must be included
