I am testing your eM Client for Mac and am on version 7.2.31850.0. I was wondering how I can set up a new smart folder for sent mail which would include query results from server and local folders. Thank you!
If the Mac beta is the same as the Windows version, then you could create a new folder by right-click on Smart Folders, and selecting New Search Folder.
You will have the option to select which folders to include.
Thanks Gary, but that’s the first thing I tried… right click on Smart Folder and select search folder options. With the beta Mac version, right click on the smart folder does not do anything.
The other way is to create the Search Folder from the drop-down arrow in the search box. Hopefully that is there in the Mac version.
Hello Dan,
for bug reporting in the Mac OS Beta, please use this email: [email protected]
Thank you.
Russel
How can we contribute to the Mac beta, I would also like to become a contributor for the same.
