Slow synchronisation
I have started using eMclient after an upgrade to Windows 7. I have an IMAP server on Outlook Exchange and things work fine, except the synchronisation is quite sluggish. Anything I can do about it?
I would suggest creating the account as Exchange rather than IMAP.  I have heard that IMAP performance with Exchange is poor.  Also, Exchange will sync your calendar and contacts, IMAP will not.  You will have to set up a new Exchange account, as you cannot change an accounts protocol.
Thank you for your support. I started using IMAP believing this would be most useful since I commute between two locations fairly frequently; eMclient at least provides stable mail handling, and I don’t feel confident about starting over.
