I can’t get slack to shake hands with EMclient and apparently its because its some Legacy ordeal. Is this accurate? Why do you guys say it works with slack when it doesn’t. I’ve been troubleshooting this for days.
Make sure you give eM Client access / permission to access your Slack account as per the following eM Client with Slack setup page.
eM Client for Slack setup page
https://www.emclient.com/em-with-slack
Also sometimes eg: Firewalls, VPNs, or Proxy services can block the WebSocket connections Slack requires. So if you have any of those try completely disabling those to test.
If you have already tried that & its not working after days, then if have a current active paid license, then contact official support via going to the VIP support page and login and lodge a support ticket. If you have run out of your 12months support, then you can get another year extention via the following page VIP Support Extension | eM Client
