Simple way to run all rules?
I’m a little perplexed (and maybe blind). Is there no way to “run all rules”?
I’ve created a new rule and want to apply it to items currently in my inbox. Is there no way to do so?
In Outlook, it’s 3 steps. File>Manage Rules and Alerts>Run Rules Now - I expected eM to be at least as efficient!
You can manually run a rule on a specific folder by “Right-clicking the folder” and then selecting “Apply Rule” , and choosing the rule you want to run.
Thanks, I’ll try that. I appreciate the reply, but it seems like extra work compared to clicking “run all rules”.
After you right click on the folder and click “Apply Rule”, you can then click “Select All” at the top and then click “Run” to run all the selected rules.
