I have only 1 email and 1 signature set up. After checking multiple times the signature and settings are set-up correctly. When I reply or forward no signature is inserted, I have to manually add it every time. How do you solve this?
You have the signature inserted after the quoted text. So when replying or forwarding, it will be at the very end of the message.
Probably better to change that to before quoted text, then you will see it right where you are typing your response.
Thank you, that worked perfectly.
