Can not get the signature i want to work. I’ve tried importing an image, i’ve tried typing a text w/ color and saving all the way. the only thing that comes close to working is when i type a signature with a custom color & font…, but when i open a reply it shows up in a black font not in the font i saved. I’d like to use a preproduced image but those won’t show up at all.
Please save me by sending the directions on how to go to signatures and open the correct files… i know all that stuff. My problem is it is not showing up at all or incorrectly. Any suggestions?
To save giving you instructions on how to create a signature that works, can you send me the snippets.dat file located in C:\Users_username_\AppData\Roaming\eM Client. I will have a look and see if there is anything wrong with it.
My address is gary.curtin@gmail.com, That way I will also be able to see how the signature appears in an email you send.
Thanks Gary. this is resolved.
TmcB
