Not sure this is the adequate English translation of that function (using the German version).
I made the unfortunate mistake to activate this on one of my most frequented folders (Gmail, IMAP), and as a result - the folder just disappeared! And didn’t show up again even when it contained unread messages …
Restart of the client didn’t help neither to get my folder back. Had to tweak with the Gmail Web-interface settings (show or not in IMAP) until it finally showed up again.
Very dangerous … please fix that!
Chris
Hi, this is show/hide function for IMAP folder, it is very easy to recover hidden folder from eM client directly.
Right click on root folder (email account itself) and select show/hide folders, there you can set what folder you want to hide or show if hidden
Jan
Cool!
Thanks for the answer and the easy solution - I am reassured
Nevertheless, while I was in this state, the folder didn’t show up - despite unread mail in it. I didn’t test this systematically though, maybe it is something you look into.
Keep up the good work!
Chris
Thank you for this report, I will give this a further testing, but so far I have never seen this not not working and I am using “hiding folders” daily for my work.
so thank you again.
Jan
