I used openssl to generate my own certificate - and I can import it successfully.
But when I try to use it to sign a message, I get (won’t let me because it considers me untrusted):
http://img1.uploadscreenshot.com/imag…
the only way how you can workaround it is to add the certificate to “Trusted” in Windows certificate store.
Thanks George,
Can you be specific, I tried moving it from Personal/Certificates to a bunch of different places without success…
Copy it to Trusted Root Certification authorities and let me know if it helps.
