Handier and quicker than left-clicking it, then having to either switch to the keyboard, or navigate the menus.
OK, we will consider it but did you try drag ad dropping the events? It is even more handy.
Hi George,
Thanks for getting back to me. I have succeeded in moving an event with drag and drop, but I can’t figure out how to copy it. Ctrl+drag/drop is the standard approach - I would be happy if you could implement that to copy.
A very common scenario for me is at the end of an appointment a client rebooks, and I want to duplicate the event.
Thanks
Ctrl+dragging works only if you copy an event to another folder but not in the calendar itself.
It would be great if you could fix it to work in the calendar itself
I think my scenario is pretty common - duplicate a calendar event
Well stated Adam. Same here.
