Shortcut to jump to search window
Before upgrading to version 11 of eM Client, I would use CMD + K to focus on the search pane. Now I’m opening a “quick select” to then enter another command.
I don’t want to use any other commands, I just want to search.
It looks like CMD + Option + F takes me back to the search pane, however, this will also trigger the “advanced search options” that I then have to escape out of before I can start searching.
Can we just have functional shortcuts back? So I can start searching for an e-mail without having to click first? You know like it used to work the past couple of years before the “new and improved version” that is again turning out to be a worse version. But hey, we got AI features…
