Where do I create OR make shortcut to “Mark as Junk and Blacklist” email?
eM Client allows you to add shortcuts to the toolbar, but they are limited.
Right-click on the tool bar and choose Customize, then select any from the list on the left you want to use:
Then it will be more easily accessible to you:
You can also use the existing keyboard shortcut - Crtl J
