We have recently deployed a Zimbra Server with a Z-push server for ActiveSync. This solution works really good with Outlook 2013. However, on EM Client, when accessing the Shared Calendars, all appointment synchronize into the “main” one. Haven’t tested the shared contacts, but it could have the same issue
This does not happen with Outlook 2013; shared calendars get created under a new calendars with the user’s name.
Any ideas?
Thanks is advance
Hello Christian, sorry for the belated reply, what version of eM Client are you currently using on your computer, can you please check the exact release number in Help > About?
I’m not completely sure what your you’re using for synchronizing your Zimbra account with eM Client, are you using CalDAV, Exchange Web Services or AirSync (ActiveSync)? Can you make a screenshot of your account settings in Tools > Accounts > Your account > …Calendar, and submit it to us here on the forum?
Hi Paul
I’m using version 6.0.22344 and using Activesync for the connection via a Z-Push server. Something interesting tho is that this problem does not happen with using ZeXtras Mobile as the ActiveSync gateway for Zimbra.
it’s most likely related to Z-push rather than emClient.
Any ideas anyone?
Thanks!
