Setting up em client with Zoho.eu
I created a business account with Zoho EU. After activating IMAP in Zoho, I tried to setup the account in EM Client. Nothing doing.
Zoho were unable to get the account activated in Em Client. Tried 3 different machines in different locations. I can configure the account in other mail clients using the standard settings but not em client. Ideas?
My configuration…
Basically plain vanilla as recommend by Zoho. I have 2FA enabled so I am using an app password.
IMAP: imap.zoho.eu
Port 993 with SSL
SMTP: smtp.zoho.eu
Port 465 with SSL
The main error I see in the logs is “Failed opening connection to server”
Is there anything I have forgotten?
And here are the logs in all their horrid glory…
22:29:21 Online state: changed to online due to NetworkAvailability
22:29:21 IMAP Synchronizing folder list
22:29:42 [IMAP] MailClient.Accounts.ConnectionException: Failed opening connection to server.
—> System.IO.IOException: Connection was closed
at MailClient.Imap.Base.Connection.ConnectAsync(Func2 getStream, CancellationToken cancellationToken) at MailClient.Protocols.Imap.ConnectionPoolEntry.ConnectInternalAsync(CancellationToken cancellationToken) --- End of inner exception stack trace --- at MailClient.Protocols.Imap.ConnectionPoolEntry.ConnectInternalAsync(CancellationToken cancellationToken) at MailClient.Protocols.Imap.ConnectionPoolEntry.ConnectInternalAsync(CancellationToken cancellationToken) at MailClient.Protocols.Imap.ConnectionPool.AcquireConnectionAsync(Folder mailFolder, Boolean noSelect) at MailClient.Protocols.Imap.ConnectionContext.CreateContextAsync(ImapAccount account) at MailClient.Protocols.Imap.ImapFolderSynchronizer.ListFoldersAsync(IListFoldersProgress progress, Folder homeFolder, CancellationToken cancellationToken) at MailClient.Protocols.Imap.ImapFolderSynchronizer.GetFolderList(IListFoldersProgress progress, Folder homeFolder, CancellationToken cancellationToken) at MailClient.Protocols.Common.FolderSynchronizer.<>c__DisplayClass16_0.<EnqueueGetFolderList>b__0(WorkerStatus status, CancellationToken cancellationToken) at MailClient.Protocols.Imap.ImapActionCommand.<>c__DisplayClass11_0.<.ctor>b__0(WorkerStatus ws, CancellationToken ct) at MailClient.Protocols.Imap.ImapActionCommand.ExecuteInternalSync(WorkerStatus status) at MailClient.Protocols.Imap.ImapActionCommand.Execute(WorkerStatus status) at MailClient.Commands.Command.Process(WorkerStatus status) --- End of stack trace from previous location --- at MailClient.Storage.Synchronization.FolderSynchronizerExtensions.SynchronizeSubfoldersAsync(IFolderSynchronizer synchronizer, Folder folder, SynchronizationPriority priority, CancellationToken cancellationToken) at MailClient.Protocols.Imap.ImapAccount.SynchronizeIntAsync(Boolean forced) at MailClient.Protocols.Common.SynchronizableMailAccount.<>c__DisplayClass7_0.<<SynchronizeAsync>b__0>d.MoveNext() IMAP_SERVER_TYPE = Unknown EnqueuedStackTrace = at MailClient.Protocols.Common.FolderSynchronizer.EnqueueGetFolderList(Folder homeFolder, Action1 completed, Boolean prioritize)
at MailClient.Protocols.Common.FolderSynchronizer.GoOnlinePre()
at MailClient.Protocols.Imap.ImapFolderSynchronizer.GoOnlinePre()
at MailClient.Protocols.Imap.ImapAccount.GoOnlineInt()
at MailClient.Protocols.Common.AccountBase.ChangeOnlineState(Boolean online, OfflineReason offlineReason)
at MailClient.Protocols.Common.AccountBase.GoOnline()
at MailClient.Accounts.AccountList.<>c__DisplayClass24_0.b__1(IAccount account)
at System.Threading.Tasks.Parallel.<>c__DisplayClass44_02.<PartitionerForEachWorker>b__1(IEnumerator& partitionState, Int32 timeout, Boolean& replicationDelegateYieldedBeforeCompletion) at System.Threading.Tasks.TaskReplicator.Replica1.ExecuteAction(Boolean& yieldedBeforeCompletion)
at System.Threading.Tasks.TaskReplicator.Replica.Execute()
at System.Threading.Tasks.TaskReplicator.Replica.<>c.<.ctor>b__4_0(Object s)
at System.Threading.Tasks.Task.InnerInvoke()
at System.Threading.Tasks.Task.<>c.<.cctor>b__272_0(Object obj)
at System.Threading.Tasks.Task.ExecuteWithThreadLocal(Task& currentTaskSlot, Thread threadPoolThread)
at System.Threading.Tasks.Task.ExecuteEntryUnsafe(Thread threadPoolThread)
at System.Threading.Tasks.ThreadPoolTaskScheduler.TryExecuteTaskInline(Task task, Boolean taskWasPreviouslyQueued)
at System.Threading.Tasks.TaskScheduler.TryRunInline(Task task, Boolean taskWasPreviouslyQueued)
at System.Threading.Tasks.Task.InternalRunSynchronously(TaskScheduler scheduler, Boolean waitForCompletion)
at System.Threading.Tasks.Task.RunSynchronously(TaskScheduler scheduler)
at System.Threading.Tasks.TaskReplicator.Run[TState](ReplicatableUserAction1 action, ParallelOptions options, Boolean stopOnFirstFailure) at System.Threading.Tasks.Parallel.PartitionerForEachWorker[TSource,TLocal](Partitioner1 source, ParallelOptions parallelOptions, Action1 simpleBody, Action2 bodyWithState, Action3 bodyWithStateAndIndex, Func4 bodyWithStateAndLocal, Func5 bodyWithEverything, Func1 localInit, Action1 localFinally) at System.Threading.Tasks.Parallel.ForEachWorker[TSource,TLocal](IEnumerable1 source, ParallelOptions parallelOptions, Action1 body, Action2 bodyWithState, Action3 bodyWithStateAndIndex, Func4 bodyWithStateAndLocal, Func5 bodyWithEverything, Func1 localInit, Action1 localFinally) at System.Threading.Tasks.Parallel.ForEach[TSource](IEnumerable1 source, Action1 body) at MailClient.Accounts.AccountList.SetOnlineState(Boolean online, OfflineReason offlineReason, IComparer1 comparer)
at MailClient.Accounts.BindingAccountBase.GoOnline()
at MailClient.Accounts.AccountManager.SetOnlineState(Boolean toOnline, OfflineReason offlineReason)
at MailClient.Accounts.DesktopAccountManager.SetOnlineState(Boolean toOnline, OfflineReason offlineReason)
at MailClient.Accounts.AccountManager.b__114_0()
at System.Threading.ExecutionContext.RunFromThreadPoolDispatchLoop(Thread threadPoolThread, ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadPoolWorkQueue.Dispatch()
at System.Threading.PortableThreadPool.WorkerThread.WorkerThreadStart()
at System.Threading.Thread.StartCallback()
22:30:28 IMAP Synchronizing folder list
22:30:49 [IMAP] MailClient.Accounts.ConnectionException: Failed opening connection to server.
at MailClient.Protocols.Imap.ImapOptionsControl.Close(DialogResult result)
at MailClient.Accounts.Mail.MailOptionsControl.Close(DialogResult result)
at MailClient.UI.Forms.formAccounts.formAccounts_FormClosing(Object sender, FormClosingEventArgs e)
at System.Windows.Forms.Form.OnFormClosing(FormClosingEventArgs e)
at System.Windows.Forms.Form.WmClose(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at MailClient.Common.UI.Forms.ThemeForm.WndProc(Message& m)
at MailClient.Common.UI.Forms.BorderlessForm.WndProc(Message& m)
at MailClient.UI.Forms.BorderlessBaseFormWithToolbar.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
at Interop.User32.SendMessageW(IntPtr hWnd, WM Msg, IntPtr wParam, IntPtr lParam)
at Interop.User32.SendMessageW(IHandle hWnd, WM Msg, IntPtr wParam, IntPtr lParam)
at System.Windows.Forms.Form.Close()
at MailClient.UI.Forms.formAccounts.stripButton_ActionButton_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at MailClient.Common.UI.Controls.ControlToolStrip.ControlToolStripButton.PerformClick()
at MailClient.Common.UI.Controls.ControlToolStrip.ControlToolStripButton.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.UserControl.WndProc(Message& m)
at MailClient.Common.UI.Controls.AutomationViewUserControl.WndProc(Message& m)
at Interop.User32.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.Interop.Mso.IMsoComponentManager.FPushMessageLoop(UIntPtr dwComponentID, msoloop uReason, Void* pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(msoloop reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(msoloop reason, ApplicationContext context)
at MailClient.Program.<>c.b__185_3()
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
at MailClient.Common.UI.Forms.BaseForm.WndProc(Message& m)
at Xilium.CefGlue.Interop.libcef.run_message_loop()
at MailClient.Program.Main(String[] args)
22:31:31 IMAP Synchronizing folder list
22:31:52 IMAP] MailClient.Accounts.ConnectionException: Failed opening connection to server.
at MailClient.Imap.Base.Connection.ConnectAsync(Func2 getStream, CancellationToken cancellationToken) at MailClient.Protocols.Imap.ConnectionPoolEntry.ConnectInternalAsync(CancellationToken cancellationToken) --- End of inner exception stack trace --- at MailClient.Protocols.Imap.ConnectionPoolEntry.ConnectInternalAsync(CancellationToken cancellationToken) at MailClient.Protocols.Imap.ConnectionPoolEntry.ConnectInternalAsync(CancellationToken cancellationToken) at MailClient.Protocols.Imap.ConnectionPool.AcquireConnectionAsync(Folder mailFolder, Boolean noSelect) at MailClient.Protocols.Imap.ConnectionContext.CreateContextAsync(ImapAccount account) at MailClient.Protocols.Imap.ImapFolderSynchronizer.ListFoldersAsync(IListFoldersProgress progress, Folder homeFolder, CancellationToken cancellationToken) at MailClient.Protocols.Imap.ImapFolderSynchronizer.GetFolderList(IListFoldersProgress progress, Folder homeFolder, CancellationToken cancellationToken) at MailClient.Protocols.Common.FolderSynchronizer.<>c__DisplayClass16_0.<EnqueueGetFolderList>b__0(WorkerStatus status, CancellationToken cancellationToken) at MailClient.Protocols.Imap.ImapActionCommand.<>c__DisplayClass11_0.<.ctor>b__0(WorkerStatus ws, CancellationToken ct) at MailClient.Protocols.Imap.ImapActionCommand.ExecuteInternalSync(WorkerStatus status) at MailClient.Protocols.Imap.ImapActionCommand.Execute(WorkerStatus status) at MailClient.Commands.Command.Process(WorkerStatus status) IMAP_SERVER_TYPE = Unknown EnqueuedStackTrace = at MailClient.Protocols.Common.FolderSynchronizer.EnqueueGetFolderList(Folder homeFolder, Action1 completed, Boolean prioritize)
at MailClient.Protocols.Imap.ImapAccount.RunIfOnline(Action ifOnline, Action ifOffline)
at MailClient.Protocols.Imap.ImapFolderSynchronizer.GetQuotaInformationAsync(Folder folder, CancellationToken cancellationToken, Action2 completed) at MailClient.Storage.Application.Folder.GetQuotaInformationAsync(CancellationToken cancellationToken, Action2 completed)
at MailClient.UI.Forms.FormFolderProperties.TabSwitcher_AfterPanelActivated(Object sender, PanelEventArgs e)
at MailClient.Common.UI.Controls.ControlPanelSwitcher.ControlPanelSwitcher.OnAfterPanelActivated(PanelEventArgs e)
at MailClient.Common.UI.Controls.ControlPanelSwitcher.ControlPanelTabSwitcher.OnAfterPanelActivated(PanelEventArgs e)
at MailClient.Common.UI.Controls.ControlPanelSwitcher.ControlPanelSwitcher.ActivatePanel(SwitchPanel panel)
at MailClient.Common.UI.Controls.ControlPanelSwitcher.ControlPanelTabSwitcher.OnMouseDown(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Application.RunDialog(Form form)
at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
at MailClient.UI.Forms.FormFolderProperties.ShowDialog(IWin32Window owner, Folder folder, FolderType folderType, String tabToActivate)
at MailClient.UI.Controls.Folders.controlFolders.menuItem_Context_Properties_Click(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at MailClient.Common.UI.Controls.ContextMenuStripEx.WndProc(Message& m)
You may have the incorrect security policy for those ports. For both of them, it should be set to Use SSL/TLS on special port (legacy).
If that still doesn’t work, as a test, can you completely disable any anti-virus, firewall, proxy or VPN, then try again. Sometimes even restarting your router may resolve this.
Hi Gary, yes, that solved the issue.
Thank you!
