Set up Problems
I cannot get eM Client set up on Windows. My main account is a gmail account and it doesn’t import anything from the Thunderbird client I have been using. So unless there are some clear instructions available for importing accounts from other clients, I will regrettably say goodbye.
This is the box that I get when I try to enter my password for Gmail.Captura de tela 2021-06-18 171001
Once you have your Gmail account working in eM Client, you can import Thunderbird mail via Menu - File - Import and select Thunderbird.
There is also options to import Thunderbird folders if you only want certain folders.
