I am running eM Client 8.2 using the command line /dblocation to access two separate databases. When I change the location of the backup target directory Menu => Settings => Backup, that change shows up in both databases (this occurs with other settings as well). Are the eM settings stored somewhere else than in the database?
Example: I start eM using database #1 and change the backup location setting, then when I start eM using database 2 it shows that changed backup location also.
Yes, this is so that the Windows Task Scheduler can execute the backup. Both the source and targets are listed in that key.
That is also why, if you have more than one database, only the one registered in Menu > Settings > General > Storage (so the same in the registry key) will be backed up.
