how could i set a different sender in the sending dialogbox?
thanks
thanks
jueves 10 febrero 2022 :: 1135hrs (UTC +01:00)
If you have more than ONE account registered in eMC you will be able to select the
alternative from a dropdown in the From field.
If you want to be able to send from an alternative name from the same account you
can use an alias providing this is registered with your email provider for which you
may or may not be charged, unless you have your own domain name when you can
do more or less what you want within the way you have it is setup.
¡Saludos desde la soleada Sevilla España!
Skybat
emc_forum@compucall.com
i want to use our exchange with different names (in outlook it is called “from”)
thanks
