see image
YOU STILL DO NOT HAVE eM Client 6.0 LISTED HERE!
hi, when you select text and then click somewhere else it will get unselected, that is normal behaviour.
About that version, I will ask my superiors to add it, but to be honest i don’t pay attention to it. For me more important is exact version which I always ask if I need it. many users do not use this field anyway.
Jan
“when you select text and then click somewhere else it will get unselected, that is normal behaviour.”
-that’s not happening, as the picture shows.
“more important is exact version”
-what’s “exact version”?
“many users do not use this field anyway”
-which field? the message-body field?
So your text stays selected when you click away?
Help - about
eM Client version here on forum, but I will ask about it.
Jan
Version 4.0.19861.0
but i have updated eM since i started this thread, so problem might be fixed. Not sure yet.
4.0… ? Or it was only misclick? Anyway if newest update has solved your issue I am marking this as solved.
Jan
will let you know. But i think this problem might only be with inserted images (the image stays selected). See pic in my OP.
thx
Ok, I was asking because I was unable to reproduce this issue so I had to make sure.
