(Version 9.2.1222 (ca10485)):
In the contacts page, there is searchbox at the top right, with the button to the right of it.
While the user is in the Contacts page, is it possible to remove the “search folders” functionality in the search box, bringing over instead the keyword search for quick contact search.
Alternately, if EM Client still wants a folder search for a user in the Contacts page, just swap the utilities of the search box and button.
Thanks.
The option is there so that the user may choose which folders to search in, in the event they want to narrow down their search. If you don’t want to use folder selection, set it to All Folders, and then just ignore the dropdown options.
Edit: Oh, hang on, I see what you mean. The Search Folder button is there so that if the user wants to make their search into a search folder, they can do that. Just ignore that button and click on Search to complete your search.
Alternatively, don’t open any of the drop-downs. Just type your text in the search box and hit enter.
Got it.
Had a problem with searching for something that should have been there but wasn’t.
