Search Not Working
Search Not working No results are not being returned at all.
Assuming you are using IMAP, by default emClient only downloads header information and the body of the message is loaded when the message is opened. Therefore, if you search for a text string in the message body, no results will be returned. You can have eMclient download the body automatically by going to menu/tools/accounts/imap and check “Download messages for offline use”. This should allow you to search message body text. The initial download can take awhile depending on your internet connection speed.
If I may come in late.  I too tried to do a search with IMAP but did not get results. I was looking for for a specific part of a sender’s email address that was Archived on the server. Can EM do search in this example?
