Search fails to match sender name
I find that the search box in the toolbar omits many obvious matching messages. In fact it does not appear to look in the From: field at all. I have 20 messages in my inbox from myself and none of them are found by searching on sonander in sender.
Searching in Subject, sender and body does appear to match body text ok, but even this search does not seem to look in the From: header.
Below is the full message for an email that fails to match a search of sonander in Sender in case the developers want to look at this. I assume these searches are done in the client.
There may be a clue in the blank line that appears part way down in the headers below. There is no blank line in the text I copy/pasted from, and the line starting b= was indented by the same number of spaces as the following lines in the source of this copy/paste.
Jeremy.
Return-Path:
Received: by saros.com (CommuniGate Pro PIPE 5.2.14)
with PIPE id 4591232; Tue, 26 May 2009 17:25:11 +0100
X-TFF-CGPSA-Version: 1.5
X-Saros-CGPSA-Filter: Scanned
X-Spam-Checker-Version: SpamAssassin 3.2.1-gr1 (2007-05-02) on
willow.saros.co.uk
X-Spam-Level:
X-Spam-Status: No, score=-2.1 required=5.0 tests=AWL,BAYES_00,
BOTNET_SERVERWORDS,HTML_MESSAGE,RDNS_NONE autolearn=no version=3.2.1-gr1
Received: from [email protected]
by saros.com (CommuniGate Pro GROUP 5.2.14)
with GROUP id 4591231; Tue, 26 May 2009 17:24:56 +0100
X-Autogenerated: group
with PIPE id 4591230; Tue, 26 May 2009 17:24:56 +0100
Received: from mail-ew0-f170.google.com ([209.85.219.170] verified)
by saros.com (CommuniGate Pro SMTP 5.2.14)
with ESMTP id 4591228; Tue, 26 May 2009 17:24:51 +0100
Received: by ewy18 with SMTP id 18so3933005ewy.14
for ; Tue, 26 May 2009 09:24:51 -0700 (PDT)
DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed;
d=googlemail.com; s=gamma;
h=domainkey-signature:mime-version:received:date:message-id:subject
:from:to:content-type;
bh=OqHg+QT1Vwsb3tLxWaZhCfWFJvqSylbELFvUs7rOjZU=;
b=CqMldnMdUPBFoIjc7gIhDtoQcVGUPiK+GmykGAHbboqG5jLmHdL/Y6QGAh8JWLCfzt
7HSHLK/5/SekikQcQtkB53pxBIeiuOB8S6jNJwaEGjKN3O042orJjMJBbmTUHd9I9pvU
3CYT8lSrtDcQ8HRe2t5HkaEeIrNLGabXI562g=
DomainKey-Signature: a=rsa-sha1; c=nofws;
h=mime-version:date:message-id:subject:from:to:content-type;
b=O1bSYCI7s3pu7TJ0sYqpwT9Akmma/FeOl47DKmAU2srz4KdIGqH3mwqfHUNXPEs8QF
Ie6YYEq5Jto7K7wHXKqGi4QOD29dAjcOfUO3fIe4QhvYQQKRK0nbWaiBjunJzTB9P9yE
6g7PYbbejgarqSMJpmKzKmnbxjfXi3gEU56+s=
MIME-Version: 1.0
Received: by 10.216.47.213 with SMTP id t63mr3250068web.134.1243355091078;
Date: Tue, 26 May 2009 17:24:50 +0100
Message-ID:
Subject: Another HDL test
To: Jeremy Sonander
Content-Type: multipart/alternative;
boundary=001485f6d2a4890d7a046ad32a9c
X-Length: 2601
X-UID: 59880
–001485f6d2a4890d7a046ad32a9c
Content-Type: text/plain; charset=ISO-8859-1
Content-Transfer-Encoding: 7bit
This one using bcc.
Content-Type: text/html; charset=ISO-8859-1
This one using bcc.
–001485f6d2a4890d7a046ad32a9c–
Hello, we know about this issue. In released version eM Client only find results when searching in from field when from starts with search string, so there is no good way to search for a domain or surname etc. Good news is that this issue is already solved in our internal builds and will be released with v. 2.6 (approximately March 15th).
It’s still not fixed as for 2.6.77
