I have just installed version 7.2.34062.0. Before this version, there seemed to be two sections in the folders scroll bar. The smart folders and search folders always remained visible when scrolling down to the other folders. Now, whenever I scroll down, the smart folders and search folders disappear from the screen as well. This makes it less easy to archive messages from the sent items to a folder way back down in my folder list. Can I fix this somehow? Is there a specific setting that I should use?
This was a change that was made in 7.2. Unfortunately there is no setting. I have seen a couple of complaints on this, so maybe eM Client will rethink the change.
