I just installed V8. First time I have used eMClient. 2 weird things are happening. The scroll speed (when using the touch pad with 2 fingers) scrolls the window at about 1000 mph. So sensitive it is unusable. The same scroll feature is fine on all other apps, superfast only on eMClient.
Also, when I read an email that has a .jpg file attached, eMClient takes FOREVER to load the jpg. It is like the old days of 300 baud dialup connection.
I’ve never used eMClient before. Can anyone make a suggestion?
Thanks much
dac
