after one of the laste updates emclient shows a lot of the same mails even if there ist only one sent and received. This can`t be right
Are you using Conversations?
If so disable Conversations using Menu > View > Conversations > Disable Conversations.
Do you still see duplicates?
If so, what folder are you in?
