Is it possible to use not only “and” in the rules, but also “or”?
Example: Move incoming emails to folder XY if “newsletter” is in the adress OR if the sender is “[email protected]”
If this is not possible - what is the workaround? A second rule?
It is already an OR argument.
Just add the address details. If the incoming message matches any of those, the Rule will be applied.
Thank you, for the replay. Maybe my example was bad. If you have two or more arguments (first rule with the subject, second with word in the text,…) you have the AND operator and not the OR.
[sorry, I use german and not the english UI ]
