The way you display/handle rules as they pertain to scope is a bit clunky in the UI. Presenting scope should be implemented in a better way. As a first time user, I had issues, but eventually figured it out. And I saw posts on here from other users having the same issue. I may have been used to Postbox’s interface where scope is presented as a dropdown list. Anyways, take a look at it if you’re not familiar with it and hopefully take it into consideration.
As written in another posting of you, I’ve assembled a list of enhancements for the rules that should be re-worked, added or enhanced: https://forum.emclient.com/emclient/topics/enhancements-for-rules
Hi Adrian, thank you for the suggestion, we’re currently working on the upcoming release of eM Client 7 which should include some enhanced rule options.
Paul
That’s great news. Hopefully it’s enough to make me a customer
