I’m new to eM Client having come from Outlook 2007.
I’ve set up some rules but they are not working. I’ve searched the forums & it would appear plenty opf others are having issues, this is a deal breaker to me as to whether or not I keep using this software.
The rule I have set up is based on my own domain name something@something.co.uk & I have this set up as a POP account.
I have created an EBay folder under my something@something.co.uk folder but the rule does not run on incoming emails nor does it run when I right click my inbox & Apply Rules
Maybe the address ebay@ebay.co.uk is not correct. One way to ensure it is correct is to right-click on the from address in the message and choose Create Rule From.
The Rule should then apply to all future incoming messages matching that address.
If you later rename or move the EBay folder, you will need to edit the Rule and reselect the destination as this is not automatically changed.
