As you can see here any right click in EM Client yield a scrunched option. This suddenly happened, and had not made any system changes prior to this.
Process:
- Checked all other program windows and all other programs work fine with right click menus
- Removed EM Client reinstalled, still same result right click
- Renamed the …AppData\Roaming\EM Client and AppData\Local\Em Client, then reran EM Client, caused me start ‘over’ with setup, still same result with right click
- Looked in Program Files (x86)\Em Client but can’t find any ‘config’ or INI setting files this might be looking at (size of window when right click).
