It would be great to have RTF for the different lists as well as for tasks. When I try and use a larger font than 12 I only see half the font.
Hi, could you please make screenshot of your issue so I can see exactly what is happening to you?
Jan
John the form field only supports up to font 12…larger fonts cause the lower 1/3 of the font to be missing as the form field is not large enough.
I have got reply from developer that we need to see screenshot of it.
Also RTF is much likely not to be implemented in foreseeable future because there would be many issues with synchronization to the server (it would most like break it’s format)
Jan
