Retrieved Emails being duplicated
Since upgrading to v11, I am getting retrieved Gmail emails duplicated. Once showing Gmail symbol; the other the account symbol assigned within eM Client.
Deleting one, deletes the other.
Using version=11.0.1201.0
Reverting to v10 before I get too far down the line with the new v11 data structure.
Hi @emteec
  • Could you let us know whether the duplicates show only in a combined view like All Inboxes or also in the account’s own Inbox folder?
  • And could you please check the UID of the duplicates? Right-click each message, select Properties and copy the UID - are they different or do both duplicates have the same UID?
Regarding going back to version 10: please note that the database isn’t backward compatible, so version 10 can’t use a database that has already been updated to version 11. So before going back, please make sure you have a backup made in version 10.
Have reverted to v10 & then reinstalled v11 for 3rd time.
Msgs now appearing just the once.
The difference this time is that I didn’t login to eM Client Sync (set up during v11 beta installation on a separate PC) during install - logged in afterwoods. Don’t know if that had any bearing on the matter.
But everything looking OK with msgs this time round.
