Reogarnizar contas
Qual o procedimento para reorganizar manualmente as minhas 5 contas de e-mail?
Hi Idacil,
Firstly, for this you need to have eM Client PRO because our FREE version has a 2 active accounts limit. Then you can add accounts manually in Menu > Tools > Accounts > Add account > Mail > Other.
Russel
Ok, obrigado. Já adquiri a versão PRO.
If you go to Menu > Tools > Accounts, you can arrange the accounts as you see fit by using the up and down arrows to change the order they will appear in the left sidebar.
