I have a question if it is possible to remove avarts from all e-mails on all accounts with one award
While Avatars were a welcome addition to many, some of you prefer simpler message list and the addition of contact icons was taking up precious space. Based on your feedback we have made it possible to easily remove contact avatars from message list in all folders at once. Or you can enable them again using the same option, should you change your mind!
eM Client: When hiding avatars you can now apply the change to all folders
dziękuję, Děkuju, Thank you
