Regular Contacts are moved to Junk and Appear as ***SPAM***
I have regular contacts being moved to my junk folder, and it happens on a daily basis.
They are not marked as SPAM on my Server’s C/Panel.
They are not in my Blacklist
eM Client will not let me create a whitelist.
They are not in my Rules to be moved to Junk.
I have a rule set to always move them to Inbox, yet they appear in Junk and are marked as SPAM.
Help.
They are not in my Blacklist.
If emails are automatically appearing in your Junkmail folder and you have no automatic rules setup to move it and you have no blacklist setup then it will be your server automatically moving it.
So I suspect your mail server must have some sort of eg: spam engine builtin and is detecting something in those senders mail header, subject or body as possible spam so puts their emails straight in the Junkmail folder at the server end.
So when they arrive in your Junkmail folder online, “you mark them as not junk” which will then move them back to your Inbox and trains your online mailbox to keep them in your Inbox.
An automatic rule to go back to the Inbox won’t work. Automatic rules are designed for new emails that arrive in your Inbox that then can be moved to other mail folders via rules.
Only some servers are supported for whitelists.
This does not work, been doing this for about 12 months.
Then suggest you contact your mail server technical support and let them know that’s happening. As you don’t have rules or a blacklist setup in eM Client then it’s mail server related.
You can usually setup whitelists though in your server mailbox end. They can help with that or advise what to do to keep them in your Inbox if your mail server doesn’t have a whitelist option.
Mail servers can also sometimes mark senders emails as spam due to eg: IP reasons primarily because of poor sender reputation, IP blacklisting, or suspicious sending behavior tied to that specific address. So that can also be why.
These are employees with similar IP addresses who have been emailing me for about 20 years and not IP black listed, as they are from the same area ie: local council correspondence in reply to an email I send them.
By the way, all your email notifications are SPAM
Then something then has changed at your mail server mailbox end causing them to be marked as spam and so going into your Junkmail folder.
Rules and Blacklists are the only way it happens in eM Client “which as you advised you don’t have either setup or enabled in the client”. So it has to be the server mailbox end.
We carnt help with that at the server mailbox end, other than to tell you to mark them as not junk at your server end which you have done and is not working.
So your server tech support is the next step to find out why they are moving to the Junk folder.
That’s not eM Client doing that. That’s either your mail server or could be some other external program synching to your same online mailbox marking those emails with the word SPAM.
Contact your mail server technical support and advised those emails are marked as Spam.
OK, will do. I’ll let you know how I get on.
Cheers
