Hi. When i delete messages from inbox i get red triangle until i empty the trash. All inboxes are on Icewarp server. This i the log:
10:32:48 ********* [IMAP] System.ArgumentNullException: Value cannot be null. (Parameter ‘source’)
at System.Linq.ThrowHelper.ThrowArgumentNullException(ExceptionArgument argument)
at System.Linq.Enumerable.Any[TSource](IEnumerable1 source) at MailClient.Protocols.Common.ItemMoveContext
2.Commit(TItem item, IEnumerable1 additionalProperties) at MailClient.Protocols.Imap.ImapMailSynchronizer.MoveAsync(IItemMoveContext
1 moveContext, Folder folder, IEnumerable1 items, Folder targetFolder, CancellationToken cancellationToken) at MailClient.Protocols.Imap.ImapMailSynchronizer.Move(IItemMoveContext
1 moveContext, Folder folder, IEnumerable1 items, Folder targetFolder, CancellationToken cancellationToken) at MailClient.Protocols.Common.ItemSynchronizer
2.<>c__DisplayClass33_0.b__0(WorkerStatus status, CancellationToken cancellationToken)
at MailClient.Protocols.Imap.ImapActionCommand.<>c__DisplayClass13_0.<.ctor>b__0(WorkerStatus ws, CancellationToken ct)
at MailClient.Protocols.Imap.ImapActionCommand.ExecuteInternalSync(WorkerStatus status)
at MailClient.Protocols.Imap.ImapActionCommand.Execute(WorkerStatus status)
EnqueuedStackTrace =
at MailClient.Protocols.Common.ItemSynchronizer2.EnqueueMove(Folder folder, IEnumerable
1 items, Folder targetFolder, Boolean prioritize)
at MailClient.Protocols.Common.ItemSynchronizer`2.GoOnline()
at MailClient.Protocols.Imap.ImapMailSynchronizer.GoOnline()
at MailClient.Protocols.Imap.ImapAccount.GoOnlineInt()
at MailClient.Protocols.Common.AccountBase.ChangeOnlineState(Boolean online, OfflineReason offlineReason)
at MailClient.Protocols.Common.AccountBase.GoOnline()
at MailClient.Protocols.Common.SynchronizableMailAccount.Synchronize(SynchronizationPriority priority)
at MailClient.Accounts.BindingAccountBase.Receive()
at MailClient.Accounts.AccountManager.ReceiveAllInternal()
at MailClient.Accounts.AccountManager.SendAndReceiveAll()
at MailClient.UI.Forms.formMain.sendReceiveAll()
at MailClient.UI.Forms.formMain.stripButton_Refresh_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at MailClient.Common.UI.Controls.ControlToolStrip.ControlToolStripButton.PerformClick()
at MailClient.Common.UI.Controls.ControlToolStrip.ControlToolStripButton.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.UserControl.WndProc(Message& m)
at MailClient.Common.UI.Controls.AutomationViewUserControl.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at MailClient.Program.<>c.b__167_1()
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor, Boolean wrapExceptions)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at System.Delegate.DynamicInvokeImpl(Object[] args)
at System.Delegate.DynamicInvoke(Object[] args)
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
at System.Windows.Forms.Form.WndProc(Message& m)
at MailClient.Common.UI.Forms.BaseForm.WndProc(Message& m)
at Xilium.CefGlue.Interop.libcef.run_message_loop()
at MailClient.Program.Main(String[] args)
