Hi -
When I receive emails they are displayed in a font so small as to be barely readable. How can I get them to display in a larger font?
Thank you.
Hi -
Thank you.
Hi Sunriseal -
Thank you for the response. Iâm not sure what it is youâre showing me, though! I donât know what âItem listsâ is referring to, but Iâm assuming itâs not the size of the font in which received emails are displayed.
Andrew
I am showing you where in the SETTINGS you need to adjust the fonts for the folder lists and email lists.
Hi again -
That makes sense, but itâs not the lists that are a problem; itâs the display of the received emails themselves. People write in different fonts - probably 12 or 14 pt - but I receive them as 8 or 9 pt, which makes them virtually unreadable. I want to be able to read them as they were written and I canât seem to be able to do it.
Andrew
Hi -
I appreciate your perserverence in trying to resolve this one for me. This is the setting Iâve tried and it does increase the font size in certain mails - presumably mails written in that font - but it doesnât affect mails written in other fonts and of course, people write mails in all sorts of different fonts. Maybe Iâm wrong, but Iâm sure it ought to display mails as they were written and not display them in a smaller font size than that in which thwey were written.
Well, I guess you can make your suggestions to eM Client by entering it in the Feature Request category of this forum and hope for the best and/or submit a support ticket and perhaps they will have a suggestion for you.
domingo 04 octubre 2020 :: 1300hrs (UTC +01:00)
Hi @Andrew_HamlingâŠ
Iâve just seen your exchanges with @sunriseal and there is something else that you can try.
At the top of the screenshot above (out of view) you can select:
Read all messages in plain text, unfortunately this causes another issue with HTML messages,
which is the probable cause of your issue in the first place, as they will only be part displayed
n text with a link to open the message in your browser with the browser default point size,
though of course you can adjust this to suit.
Just a thought.
¥Saludos desde la soleada España!
Russ
@Andrew_Hamling If you have EM Client Windows, (when reading any email), âHold down the Ctrl keyâ and while holding, âScroll your mouse wheelâ forward and backwards. This will increase or decrease the fonât reading size.
Sunday 04 October 2020 :: 1431hrs (UTC +01:00)
Hi @cyberzork
Brilliant - I knew that ctrl + mouse scroll works in a browser and
other stuff and I never thought to try it in eMC
Russ
Thank you skybat and cyberzork for your responses. Theyâre much appreciated. âHold down the Ctrl key and scrollâ - so simple! Thank you cyberzork. Youâve saved me an awful lot of eyestrain.
Andrew
Ctrl+Mouse Scroll: As I always say, you learn something new every day⊠thanks!!!
Now all I have to do is remember it
