Quickbutton rules
hi
if you clicked on the right mouse button you could apply the rules to the specific folder, where is it now in the new version
thx
v9
The exception in version 9 is that Apply Rule is no longer an option for the default Favorites folders. So you can’t use it with All Inboxes, or Unread for example.
It will still work with all the other folders, or those you have manually added to Favorites.
