Hi, I am using the free version of eM Client for some years now. A few weeks ago I had to reinstall my computer, my mailfiles are saves on another computer. Can someone tell me how to reinstall eM Client without losing my old mailfiles ? Thanks a lot in advance
If you want to move eM Client from one computer to another, the easiest way is to backup on one computer then restore on the other. You can do that through Menu > File > Backup.
You also want to deactivate the Free License on the old computer, before you activate it on the new one. You can do that through Menu > Help > License > Deactivate.
If you no longer have eM Client installed on the old computer, or you just have the hard disk, you want to copy the complete C:\Users[username]\AppData\Roaming\eM Client\ folder from the one computer to the other. eM Client needs to be closed for you to do that.
