Is there a way to use a wildcard in the rules? For instance, I would like to file all email from *@wsu.edu to a particular folder, rather than have to add each account that I get from them.
You don’t need a wildcard for filtering a domain. Simply add ‘@wsu.edu’ as an address in the rule filter and it will work.
Thanks, Champ.
Couldn’t find my other issue, but got that fixed with a new build.
