Question about difference between eM Client and Outlook?
In the eM Client is there something similar to “notes” in outlook? After reviewing the web site it doesn’t seem so. Please advise. Also, can you drag and drop items from the “inbox” into your calendar? Or drag and drop files you want to attach into a message, or do you have to use the “attach file” menu item like you do in thunderbird?
I am sorry but eM Client does not contain anything like Notes. We are considering implementation of this feature, but I cannot tell you when (or if) it will be implemented.
Drag and dropping of items to calendar is possible and drag and dropping of attachments works too.
