Quality problem displayed images (v10.1)
i have an issue with embedded images.
  1. If i add an image it will be resized to a slightly lager size. It will stay at that size regardless if i choose “original” quality afterwards or set it as default in the settings.
  2. Not only will the image get blurry but also the color is slightly off.
This is the same for composing a mail as well as opening the mail sent to another account (also with em client).
Here’s a comparison between em client on the left and the windows image viewer on the right.
If i download that sent image and open it in the windows viewer it will be the same as the original. So the image itself has not changed, just the displaying of it.
Anything i can do?
