Can you check using the web interface for GMail and see if the same contacts and sent items are duplicated?
If they aren’t then it probably means that your eM Client database is corrupt. Because this is a GMail account setup as IMAP, your best bet would be to remove the account from eM Client, then add it again. To do that go to Menu > Tools > Accounts and delete the GMail account. Then in the same screen you can add it again.
looking on google gmail site only one sent email is duplicated. i’ll keep my eye on that over the next few days.
also on the google gmail site non of the contact have duplicated at all.
will try what you advise.
get back to you later
regards
jh
I don’t receive any message on email. neither on gmail. the only message I receive is on my Ipad on another messagerie
can you help me please
greeting
marie montandon email: [email protected] or [email protected]
