I ve changed the name of some folders and after that I “lost” many mails…Even doing an “actualize” the old emails dont appear… In the original gmail account of course the mail are there…
Shall I to reinstall everything?
If you renamed folder in gmail make sure the show IMap is cheked on gmail so it will show up on emclient.
Where di you rename in gmail on emclient
what do you mean actualize
Old emails do not appear your mean the old folder names ?
what version of emclient
You could also try to repair the folders. Right-click on the account folder and choose Properties > Repair.
I’m having this same issue, was there an actual resolution. I created the folder in EmClient and moved emails to it. The folder shows up fine in Gmail, but has disappeared in EmClient along with all the emails. The funny things is I can search for one I know is in that folder and it finds it and hovering over categories shows the new folder name I created, but the folder is not there. Help! I tried the repair, nothing. I have tried restarting EmClient, nothing.
Move your mouse over the account name in emclient in the mail screen right click and you will get a pulldown one will say hide/show click that and see if the folder you created is hiddden or not.
Also check in gmail settings labels that the folder you created has the Show in Imap is checked.
also All mail must be checked Show in Imap.
I had already tried that and they were not hidden. I ended up just removing and re-adding the account and everything was there. Note to self, make the changes in Gmail and not EmClient, seems to work better.
